Trouble shooting old amplifier, crap using it for party tonight....
0 Members and 1 Guest are viewing this topic. Read 1205 times.
Folsom
I have isolated a problem to my amplifier as best as I can. The only other thing that could cause this would be the cable.
Basically at most volume everything is fine. However as I increase the volume the right channel gets more and more distortion and eventually is MUCH quieter than the left channel.
Inside the amplifier I see no blown capacitors. I smell nothing burning. I really am not sure what the problem is! I checked to see if anything was touching anything else and I see nothing...
Any ideas? I was hoping to use it for a party tonight...
Soundbitten
Play Halloween music .
ctviggen
Do you have a voltmeter?  Can you check the rails (the positive and negative voltage, assuming the amp is DC coupled, that is)?  If it's only one one channel, this probably isn't the problem, though.  If you can figure out which is left and right circuity, you can play a test tone through both and go from the input to the output to see what is different.  If you get a radically different voltage somewhere, that's your culprit.  Typical amps are three stage -- transimpedance (voltage to current) (typically, using a current mirror), transconductance (I think -- I need to look this up; current to voltage), then a current amplification stage.
