Trouble/bug on SP2...
0 Members and 1 Guest are viewing this topic. Read 2356 times.
MOZ
« on: 31 Oct 2006, 10:54 am »
Hi everyboby, Hi James,
I'm having a strange trouble with my SP2...
It happened twice since i got it back from the upgrade.
When i want to turn up the volume a bit more (for exemple) the screen on the SP2 stays black, nothing appears on it and the volume doesn't increase.
If i do it manually, nothing happens.
Then, if i try to change manually the mode, for exemple switching from stereo to surround mode, then the volume goes from reasonable to VERY VERY loud (with a loud distortion) and nothing can be done to reduce it apart from switching the SP2 to the off position...
It didn't break my speakers but it was just limit to do some damages...
Has anyone encountered this before ?
James are you aware of such a bug ?
What should i do ?
Thanks by advance...
MOZ
  • The Demo is Everything!
    • http://www.bryston.com
Re: Trouble/bug on SP2...
« Reply #1 on: 31 Oct 2006, 12:29 pm »
Hi MOZ,
Sounds weird - what software date are you using?
james
MOZ
« Reply #2 on: 31 Oct 2006, 12:32 pm »
Hi MOZ,
james
I'll check tonight...
It doesn't happen a lot (twice, as i said) but it is quite frightening when it happens...
MOZ
« Reply #3 on: 2 Nov 2006, 07:51 am »
Hi James,
Here are the facts :
SP2 OS V1.5
AUG 04 2006
DSP F/W 0000402
« Reply #4 on: 2 Nov 2006, 10:13 am »
Hi James,
SP2 OS V1.5
AUG 04 2006
DSP F/W 0000402
Ok email me at Bryston and I will send you some new software.
james
MOZ
« Reply #5 on: 2 Nov 2006, 02:08 pm »
Done...
« Reply #6 on: 2 Nov 2006, 04:52 pm »
Done...
Hi MOZ - sent software this morning.
james
brucek
« Reply #7 on: 2 Nov 2006, 06:40 pm »
SP2 OS V1.5
AUG 04 2006
DSP F/W 0000402
Since this is the latest software available on the site, I guess you're sending a newer beta version.
What has changed? Perhaps being able to force Dolby Digital EX ?  :)
brucek
Hi brucek,
Not sure I understand your comment about force DD-EX - do you want to force the input to always default to DD-EX when back speakers are engaged.
james
« Last Edit: 2 Nov 2006, 08:53 pm by James Tanner »
« Reply #8 on: 2 Nov 2006, 07:17 pm »
No same software.
james
MOZ
« Reply #9 on: 3 Nov 2006, 08:02 am »
Thanks a lot JAMES...
I'm seeing my retailer friend tomorrow i'll ask him to do the FW upgrade (i have his computer/EQ'ing system at home :) )...
By the way, we've done a new EQ of the new subwoofer and i simply rediscover my all system with this new one !
Amazing how the things change with a great sub (TRIAD PLATINIUM THX)...
MOZ
MOZ
« Reply #10 on: 3 Nov 2006, 01:29 pm »
James,
Will the F/W flash erease eveything that we've programmed on the SP2 (levels, settings aso) ?
MOZ
« Reply #11 on: 3 Nov 2006, 02:40 pm »
NO
james
