D200's and a subwoofer, or 2 subwoofers.
0 Members and 1 Guest are viewing this topic. Read 1820 times.
DaveX
« on: 30 Oct 2006, 04:04 pm »
If I were to add a subwoofer to the D200's.
The speaker cable is 3 core (L/R + ground) am I right in saying that you would only ground one D200.
And using 2 subwoofers (one on each amp) you would twist the L/R wires together.
Thanks.
CIAudio
Re: D200's and a subwoofer, or 2 subwoofers.
« Reply #1 on: 30 Oct 2006, 04:12 pm »
For a single subwoofer, you will use L+, R+, and - from either amp (ground is common).
For two subs, use L+ and L- for one, and R+ and R- for the other.
Never tie L+ and R+ together, this will destroy the amplifier.
DaveX
« Reply #2 on: 30 Oct 2006, 05:24 pm »
I meant if I twist the L/R (white/red) wires of the 3 core cable together this would give me one + channel and the third wire would be the - ground.
CIAudio
« Reply #3 on: 31 Oct 2006, 12:04 am »
I'd ask the sub manufacturer regarding the above...
It also depends on if you want separate L and R woofers, or two mono's.
There are probably a few ways you can wire them.
