DavidS,
To go the audio PC/Squeeze Box route you need:
- free downloads of EAC (Exact Audio Copy), FLAC (Free Lossless Audio Codec), and Slimdevices software
- sufficient hard drive space to store your music (I suggested a 400 GB hard drive, because that's how much memory you'd need to store 1000 FLAC compressed audio CDs. However a purdent person would buy 2 hard drives and use one as a backup.)
- The Squeeze Box (SB) is then connected to the PC that via USB cable or wirelessly if you have a high speed internet service and wireless local network there. The Squeeze Box then plugs into your integrated amp, pre-amp, or just your power amp. (As the Squeeze Box has a high quality digital volume control and interfaces with internet audio streaming, you can do without a pre-amp or tuner.)
- Once you get through the setup (I barely did with help) and can keep it running (I had network/PC issues to the point I bailed out, but a modified SB was my the source in my main system) you're done. If you're computer savy it should be no problem.
One of the confusion factors is the number of options that the Squeeze Box offers. The SB has digital outputs, so some folks use it (in combination with the PC) as a "transport" and send the digital signal to the DAC of their choice. The SB also has digital inputs, so you could use it as a DAC. Or you can use it as I described above with the PC to replace a CD player and internet "radio" for audio streaming.
And the SB can be fully modded, or just the digital half, or just the analog portion. Fully modded its sound quality rivals Benchmark, Scott Nixon, and other similar DACs.
Squeeze Box offers better sonics than just using a PC and with it's remote and large display, the most convenience possible (after you've ripped the CDs onto the hard drive). Additional SB's can be added wirelessly throughout the house that can simultaneously use the PC to play different music throughout (of course you'd need to add some sort of powered speakers or amp/passive speakers at each of those locations).
Sonus is a similar product, but I'm not aware of audiphile mods for it. It's remote includes the display.
