Need some help
0 Members and 1 Guest are viewing this topic. Read 2445 times.
Tubes 4 Ever
Need some help
« on: 26 Oct 2006, 11:43 pm »
Got a Fisher X202C, that was presented to me as a working amp needing some TLC. Well it needs TLC and is not working. Needless to say the other trading partner is now missing in action  :evil:, oh well one bad deal in dozens  :duh:. I am looking for a repair tech and or advise. My OPT 7591's are overheating, getting red. I am no electrician so I am hoping someone would be kind enough to help me troubleshoot or refer me to a good tech that won't take me to the cleaners.
Tanks
Tim
warnerwh
Re: Need some help
« Reply #1 on: 30 Oct 2006, 05:34 am »
Get ahold of Mike Williams of Radio X tuners. Good work and very reasonable. You may want to try the forums at audiokarma.org also.  Audiokarma is dedicated to vintage gear.
slbender
    • The Bender Rebuild Vintage Amplifier Pages
Re: Need some help
« Reply #2 on: 2 Jan 2007, 07:19 pm »
From the symptoms you have given, it could be resistors that have gone out of spec, or leaky caps, a blown bias power supply ( usually the old selenium does go bad ) or shorted opt transformers, or actually bad 7591 tubes. They could be so weak, they are burning themselves up ( and also the other stuff too ). So it could be one thing or five things simultaniously.  Sounds to me you need a major rebuild, expect to spend quite a few bucks on the amp to prevent future trouble. My guess, even if you find a tech willing to be nice about it, it still could cost for a quad of tubes and lots of rebuild, about $300 bucks.
-Steven L. Bender
Tanks
Tim
