0 Members and 1 Guest are viewing this topic. Read 6305 times.
(To be complete, there's yet another form of transformer-coupled passive preamp that uses a 1:1 input transformer with a resistive attenuator plus fixed resistor across the secondary to create an idealized constant rather than varying load for the transformer and insure linear impedance matching regardless of attenuation. MagneQuest's forthcoming Ingot designed in collaboration with Steve Eddy is one such device and will eventually be offered with optional valve or battery-powered JFET buffer.)
You can also replace the fixed resistor R1 with a 20k ohm pot or stepped attenuator and call it Sistah Steve's Buffered Passive Preamp.
But, even better, and this is where kismet comes in, I just happen to have an exact pair of your (then) suggested Jensen 1:1 transformers sitting on my desk awaiting Eight Part Harmony.Any advice or component changes (learned since back then) if I want to wire one up for comparison with my own S&B TVC?
Hehe. Kismet indeed.
Well, first let me figure out what it is you're wanting to do exactly.
I've been waiting a long time to work that word into a post.
Nothing big, just make the perfect preamp! (just joking)
Sorry about the confusing post, I ended up mixing two seperate issues; 1) your Jensen buffered volume control, and 2) my TVC needing an optional gain stage for my phono.In reality, to solve #2, I just need to get another phono pre that puts out a full 2V or better. Unless switchable, the 24V Aikido stage's needed 15dB gain would boost my dac's output to 6V. That's going to push the TVC deep into distortion territory below 40-50Hz. So that won't work.
So, back to #1. One thing I have noticed is that my TVC has amazing dynamics, transparency, ease, tonality, and space. But, I have also noticed that a few active preamps have greater drive (the tension or force within dynamics) and a "meatier" presentation.
I was wondering if your buffered transformer volume control(b-TVC) might have both the positive sonic traits of a TVC along with the drive and meat of an active?
If so, I'd like to use my pair of Jensen JT-11P4-1-1 to build a buffered preamp and compare it with my TVC.
One thing though, the spec sheet says the 11P4 has a typical input Zi of 11.8k Ohms and an output Zo of 3.36k Ohms at 1kHz. Would the constant load seen by the source be the 20k attenuator across the transformers secondary? What would be the output impedance?
hope this makes mroe sense
No, it wouldn't work too well that way, but I thought you were thinking of using the Aikido after the TVC rather than ahead of it. That'd still give you a lot of excess gain, but you wouldn't have to worry about saturating the TVC.
As for the phono stage, see if you can find out what its output impedance is. If it's reasonably low, say 100 ohms or so, what you could do is use say a 150 x 4 line output trannie wired 1:2. That would give you about 6dB more from your phono stage
I've always thought that much of what people have liked about TVCs has had less to do with their acting as a volume control than their simply being a transformer.
Would you be up to buying a second pair of them?
Reason I ask is because the design has evolved a bit since the original. It's now fully balanced, push-pull using a Gilson source follower and has about 6dB of voltage gain.
Reason I asked about getting a second pair is that the 1:2 input trannie is made up of two trannies (which gives you the voltage gain). That's not an absolute requirement however. You could use a single transformer and a pair of 10k attenuators and let those form a virtual center tap.
Yeah, I thought about that, but it seems to be an inefficient solution. Reducing an already weak signal and then boosting it up multiple times beyond the original is asking for artifacts.I'd rather start with sources of nearly equal, but sufficient output/headroom, and attentuate that signal going to the output amps. (provided your buffer is unity gain)
I emailed Gram Slee about the output impedence, but he was a little circumspect in his answer: "The Era Gold can drive down to 600 Ohms, but it won't give you the volume you're after if 1.5 V is required. You need a line stage such as an active preamp after it to do that. A passive will reduce your volume further. A battery preamp shouldn't be necessary as the Era Gold does it using a mains supply and has a gain of nearly 1,000 (due to RIAA EQ) at mains frequencies. Thus a preamp with a gain of 2 or 3 would have to be atrocious if it added hum or mains noise modulations."
Now, there you go, ruining a great conversation by injecting some common sense You know, having had TVC's for 2-3 years and closely following the evolution since Thorsten L. first proposed the idea on Audio Asylum 5-6 years ago, I have never, ever, seen anyone mention that basic observation. Go figure
Would a line transformer load the source the same way TVC's do at low frequencies? Stevens & Billington have a table on their website that shows their TX-102 input impedence at 1kHz rising from 1.28M@-22dB to 2.5M@-46dB. I'm guessing that it is even higher at lower frequencies. That must really "take the load" off a sources output stage.
I think this has a lot to do with why many of us prefer the sound of TVC's - low level listening has a much more full body and bass to it. Of course, the polar opposite happens at extremely high levels of volume. Guess you can't have it all.
Now, that's what I'm talking about!! That's actually why I bought the Jensen 11P4's in the first place. I wanted to run 30-40' balanced cables around my living room wall to my amps next to the speakers on the other side of the room. Balanced out from the TVC to the Jensens at my SET amp's inputs.
Not sure I follow that completely. The input transformer in the new diagram is actually two identical transformers connected together?
Then, what is that on the buffer's output? A choke? Or, just the secondary(or primary if turned backwards) of the second tranni?
Would I still use the JT-11P4-1's or hould I buy different models from Jensen(or whoever)?
Regarding sources, I've toyed with the idea of putting SE to balanced x-formers in their chassis, but that can get expensive. Of course, this hobby is expensive anyway.
Anyway, I like the idea of your new preamp.
Jeeebus! 30-40 FEET!? Sure you can't optimize your equipment placement a little better than that?
Well, there are three transformers total. Two input trannies wired together at the input, and the center tapped choke made from a single quadfilar output trannie.
Ideally I want to have a custom choke made for it as I'm simply using the wiring resistance of the output trannie to self-bias the JFETs and I'd like to have a bit more resistance.
I like the 11P4-1s as they have a slight amount of voltage gain and don't have the 2-3dB insertion loss that a 1:1 has. I've been trying to talk CineMag into making a similar transformer...Also, unless you want that additional 6dB or so of voltage gain, you can just use one per channel rather than two.
Though in the case of your phono preamp, a 1:2 output trannie would give the benefit of providing a bit more voltage gain.QuoteI've decided to get a new one anyway, so I don't think the boost will be needed. Maybe a used one of George Wright's tubed beauties. One last question about the new diagram, I assume that it requires stereo attentuators for each channel or a quad deck for both.
Yeah, it's a quite a goal. The biggest roadblock is the cost of good balanced cables that long. As I said, it's a goal.My room is 15'x20' with speakers along the short wall. I'd like to get the equipment rack and turntable as far away from my subwoofers as possible. Not to mention, across the room would place everything much closer to my lazy ass on the couch. Jumping up and sprinting across the room to flip LP's is a pain. This was it would only be two steps.
I'm having a pair of gigantic rear-loaded cornerhorns made in a few months (and I mean BIG) that will use vintage 15" RCA LC-1C coaxial drivers designed by Dr. harry Olsen back in 50's. The cornerhorns are supposed to 94dB sensitive at 26Hz. (see the design and cabinets here). Crazy frequency response. Anyway, I want to get my turntable as far away from them as possible.
As the beer commerical says "Brilliant!!" Ok, get it now with the new diagram. Man, that's one elegant design - so clean & simple. Probably hides a lot of serious thinking underneath, though.
Might be worth waiting for then, unless I can find a nice, affordable pair of output trans for the mean time.
Perhaps, I'll try it with the single JT's first and see how it goes, then if I need a little extra get more.
Jensen's HQ is actually 40 miles from my house. Of course, 40 miles in Los Angeles can take 30 minutes or 3 hours depending on day and time of it.
But, I think 3V out of my dac and a 0.7V input sensitivity should do nicely.
Just seems to me there's gotta be a better way than 30-40 foot interconnects.
By the way, you when you say "and I mean BIG" do you mean they'll be larger than the one in the plans?
Well I have to give credit where credit is due here. The inspiration came from Susan Parker's work with her Zeus amplifiers and a 1978 patent by Warren Gilson.
No, they'll be to the exact dimensions. No need to ad-lib on the good Dr's plans, he did know a thing or two about audio.
I've tracked down a pair of the LC-1C's that someone is interested in selling. They aren't in perfect condition, some of the conical radiators on the cone are dented. Although, Bill assured me it won't make a noticable difference. One thing for sure, they aren't cheap.
I remember when she started that inspiring thread, really cool idea. I followed it really closely early on - came very close to building some, but I decided to upgrade other parts of my system instead.
I'll check with CineMag on those chokes Monday or Tuesday.
When it comes to phono preamps, what sort of upper output impedence would be best? You mentioned earlier that an output "of not much more than 100 ohms" wouldn't work so well with the 1:2 transfo.
Just that when you said "and I mean BIG" I'm thinking something on the order of the Jensen Imperials. Or a Tannoy Westminster or something.
Speaking of Japan, did you see that JBL/Tokyo photo essay a while back?
Yeah, though she sure had her detractors early on.
So I'd recommend no more than 600 ohms if possible. 1k as the absolute max.
I woke with several questions I should have asked at the beginning of this thread, in reference to the difference of "drive" or "dynamic tension" between most passive and actives:1. Why doesn't the resistive pot in most active preamps cause the same HF rolloff/source loading problems as resistive passives?2. Is it the following 12-15dB gain in actives that provides the sense of "drive" and "dynamic tension"?3. Is it the active stage, period that provides that sense?4. Would a unity gain buffer with high input impedance/low output impedance before a TVC add the active sense?
Thank God, I don't have to go that big! I'm on thin ice around here to downsize as it is. I've agreed to just one main system and am hoping the corner horns will get back a lot of the living room real estate my current setup is hogging. Currently, 30% or more of the room is taken up with my IM-Bens + dual subwoofers. But, these RCA's will really have to kick ass in all areas, not just bass, to outperform the Cain & Cains.
Yep, someone should arrange vacation packages/tours for things like that. I applaud the Japanese's fanaticism and dedication, but damned if they don't make it expensive for the rest of us.
There were a lot of "experts" who were dead-set that it couldn't work without every really thinking it through or trying. Susan did a great job of maintaining composure, I'm not sure many men could have done that without getting personal. She calmly tried to answer all questions and provide masurements.
Man, I was looking at phonos last night, that's a tough requirement. Most I could find were in the 1k to 2k impedance range, if they provide the number at all. Seems like only the really best have real low output impedance. I can afford ~$1,200 new or used.
The limit of the input voltage to the TX-102 depends upon the exact frequency and also the source impedance. For a source impedance of 600 Ohm and the unity gain connection a maximum level of +20dbu (7.75V RMS) is permissible above 40Hz before distortion becomes problematic, at 20Hz +14dbu (3.875V RMS) are permissible.
Output of my cartridges(needed gain to get to 2V):Grado "The Statement" - 0.50mV (72dB)Denon DL-103D - 0.25mV (78dB)Cartridge Man MM3 - 4.00mV (54dB)
Yeah, it could handle 3.9 volts...I'm not sure I'd worry too much about the S&B.
Then, it looks like we've got a nice preamp shootout in the makings - straight TVC vs. Aikido TVC vs. Buffered transfo VC.
