0 Members and 1 Guest are viewing this topic. Read 2236 times.
It doesn't give me a cost? Anyone know?
Woodsea: I'd be inclined to go with an AVA Fetvalve amp for your 626's. They sound very clean and make your cd's sound better without losing anything in detail. It also adds some body to the midrange panels.
Also are the trinaural available, and has the cost gone down?
Thanks, Michael! It doesn't give me a cost? Anyone know?Also are the trinaural available, and has the cost gone down?
Mapletree does have a 3 channel; I have one. In fact they make a 6 channel pre. Mine is the Line 3 SE. It has 2 L/R channel outputs and 2 summed channel outs, one of which I use for a powered sub. The second summed channel could be used for a powered center speaker. My pre may be one-of-a-kind but I'm sure you could commission one. Check with Dr. Peppard about the cost. The 5 channel is listed on his web sight.Raja
rajacat, could you give any comparison between your Mapletree/gc and Scott LK-48? My Scott 222c has a center channel out that can be used for a sub as well, I am told. Have ordered a cable to try that.Sorry if this is too OT .Don
