0 Members and 1 Guest are viewing this topic. Read 3545 times.
What else is needed? Any XO rework?Tell me they're a 15-second retrofit and I'm in.
You will be getting my order in January, when I am back in the states. How about my center channel?
Do the CDWG's work with the spiral ribbon tweeter?
I'm close to deciding to send in my 626Rs, but I have a couple or 3 questions - 1) The sensitivity goes down when the CDWG is in place, I think I read by 1.5dB. What does this mean in real terms? With my passive preamp (Sonic Euphoria) I lsten mostly with the volume control at around the 1:00 position - will this be a problem to achieve the same volume level?2) I currently have my 626Rs toed-in to cross 2 feet in front of my listening position for best imaging. Will I need to change the set-up? Are they better pointing straight ahead with the CDWGs in place?3) If I don't like the CDWGs (not that I imagine I won't like them, but what if?), and I decide to remove them, is the speaker's balance messed up so that they only sound good with the waveguides in place? The x-over changes and dehorning the tweeter must seriously affect the speakers' high end.Thanks for the replies.Mike Fox
At long last CDWG's for 626R owners are now available.They are avaialble in any color and finish as long as it is Piano Black They are $180 a pair plus shipping.
