0 Members and 1 Guest are viewing this topic. Read 12367 times.
http://fredt300b.smugmug.com/gallery/2040368/3/104742208
Quote from: FredT300B on 23 Oct 2006, 08:44 pmhttp://fredt300b.smugmug.com/gallery/2040368/3/104742208This open-baffle, dipole (bass and MR) system was the best-sounding at the RMAF, in my and many others' opinion. It was VERY detailed...transparent...open, spacious, dynamic, etc. My personal preferences would have several dB less treble and more bass, but more good news is all that's quickly programmable (by Emerald); the DBX (?) digital eq. stores many contours.Only $6750 per pair.
The subwoofer isn't a dipole, its a quadrupole. I confirmed this with the designer.
Is not the biggest Achilles heel of OB decreasing maxium output as frequency decreases?
i am doing some research trying to find out if i could built my own OB but i realize that there are a lot variables . which driver , tweeter , sub . what design etc....
When treating the bass problems arising from OB vs. box speakers, the OB's excursion & power handling seem more difficult obstacles than the box speakers' room modes.. but exursion & power handling are still difficult.
With all due respect, & absolutely not being a wise guy in any way...in any comparison of two speakers one might say the speaker w/ less bass is more clear.
I'm considering OB only in the 2-octave band 70-280 Hz (the lower range will be sealed, the range above is a panel array).
My goal is to minimize the rear wave bouncing against the cone's back side, muddying the sound.
Lateral quadrupoles are terribly inefficient. The examples I know of (almost all theoretical models, not actual working ones) are designed as horizontal arrays. I can´t see what the advantage of a vertical quadrupole should be. Did the designer explain his reasons to do so to you?
Rudolf, it's a longitudinal quadrupole (+--+, 2 vertically stacked if you wish).
Quote from: RibbonSpeakers.net on 28 Oct 2006, 03:46 amI'm considering OB only in the 2-octave band 70-280 Hz (the lower range will be sealed, the range above is a panel array).In this thread you are mostly critizising what others do, but only now revealing (sparsely) what YOU intend to do.
With your range decision
you are effectively ruling out the most convenient dipole configurations aka H- and W-frame...To reach 70 Hz would necessitate a really large flat baffle or something like two octaves of 6 db/oct EQ for a 50 cm wide OB.
So many people would recommend a W- or H-frame here (which could happily support 40 Hz too).
At the opposite end of your range, 280 Hz would be VERY near to the typical first manifold resonance of those W- and H-frames. You would need a 24 dB/oct. LP at least to subdue that resonance effectively.
Without necessity you are pushing yourself into the situation you don´t want: the need of much EQ at the lower or upper end of the passband. If you could move that band to 40-160 Hz (two octaves too) you could happily get away with some proven W- or H-frame solution, demanding much less EQ. QuoteMy goal is to minimize the rear wave bouncing against the cone's back side, muddying the sound. Funny, that you intend to stop with the OB just were the bouncing really starts (280 Hz).
Quote from: Rudolf on 28 Oct 2006, 08:59 amWith your range decision I'm looking for the two octave range 70-280 Hz.Quoteyou are effectively ruling out the most convenient dipole configurations aka H- and W-frame...To reach 70 Hz would necessitate a really large flat baffle or something like two octaves of 6 db/oct EQ for a 50 cm wide OB.OK, this is what I like, hard numbers. 20" wide baffle & 12 dB of EQ over my two octaves. So...let's say you have a closed box w/ 89 dB senstivity & 400WRMS power handling @ 4-Ohms (reasonable, easy to accomplish). For an OB design w/ a similar 89 dB sensitivity to equal the output of the above system would require a SIX-THOUSAND FOUR HUNDRED WRMS POWER AMP & THE SAME POWER HANDLING IN THE DRIVERS!!!!!!!!!!!! That is an astounding fact. If accurate this certainly demonstrates well the shortcomings of OB design & fully explains their general neglect in the marketplace. This is not meant as an attack or claim that the design is inferior overall or anything else. It is not an attack on anyone who loves these designs. It's just an interesting point.
