Rebuilt MLS RM40 review
0 Members and 1 Guest are viewing this topic. Read 3300 times.
john1970
« on: 21 Oct 2006, 06:27 pm »
Dear Everyone,
Approximately two weeks ago I received my rebuilt RM40s with the following options (or upgrades):
1) Supermax OXO (external crossovers with Bolder silver wire throughout)
2) MLS maple cabinets with 4 sheets of Blackhole 5 / cabinet
3) TRT capacitor upgrades
4) MLS Piano Black CDWGs (although I am currently NOT using..see below)
Improvements:
1) MLS cabinets have less resonance than the old stock cabinets
2) The MLS finish is superior to the stock finish cabinets.  If you are going to order a pair of VMPS speakers THE MLS FINISH IS A MANDATORY UPGRADE!!!
2) Bass sounds cleaner and deeper that the old pair of RM40s
3) Midrange and tweeters are cleaner than before
The only issues I have are with the newly designed MLS CDWG grills.  I wish that Brian would have kept the original design of the CDWG that incorporated a grill cloth.
Issues:
1) The piano black finish shows every fingerprint and minor imprefection.
2) The lack of a grill cloth over the midrange panels and ribbon tweeter provides no protection from the physical surroundings (a big concern if you have children).
3) Looking at a grill cloth is more pleasing than looking at raw speaker drivers (which is a big issues when your speakers are in your living room and you don't want to upset females).
I wonder if Brian could have MLS build me a set of CDWGs with cloth covering the entire grill.  :scratch:
So for now I am using the rebuilt RM40s with a standard speaker grill.  When using the standard grills I have found it necessary to turn down the treble pot to 10 o'clock position, but I have left the midrange pot at the 12 o'clock position.
With or without the CDWGs the speaker sounds absolutely amazing and easily  competes with speaker costing 2-3 times the price.  With the stock finish, one could always noitce that more expensive speakers had a nicer finish..this is no longer the case with the MLS cabinets.
Best,
John
« Last Edit: 21 Oct 2006, 07:09 pm by john1970 »
Brian Cheney
    • http://www.vmpsaudio.com
Re: Rebuilt MLS RM40 review
« Reply #1 on: 21 Oct 2006, 06:35 pm »
We will supply the CDWG with grillcloth on request, no charge.
ctviggen
« Reply #2 on: 21 Oct 2006, 06:48 pm »
Coolness.  I would also rather have the grill cloth (though I do know that it likely reduces the "transparency" -- pun intended -- of the speaker).
john1970
« Reply #3 on: 21 Oct 2006, 07:10 pm »
Brian,
Should I send back the standard MLS CDWG for retrofitting of a grill cloth?
Thank you,
John
P.S.  The new speaker is your best work yet...Congrats  8)
Brian Cheney
« Reply #4 on: 21 Oct 2006, 08:22 pm »
Send to Itone Service, 2031 Rumrill Blvd #6 San Pablo CA 94806.  Strap the grills to a slightly larger piece of plywood and wrap with cardboard.
john1970
« Reply #5 on: 21 Oct 2006, 08:42 pm »
Brian,
It will be a couple of weeks before I send it back.
Thank you,
John
john1970
« Reply #6 on: 21 Oct 2006, 11:59 pm »
A good sense of humor is always appreciated  aa
John
zybar
« Reply #7 on: 22 Oct 2006, 02:23 pm »
The MLS RM 30's at RMAF are stunning and look tremendous in Ebony Maccassar.
Nice job Mark and Brian.
George
timr
« Reply #8 on: 14 Feb 2007, 01:22 am »
Has anyone thought about or tried this...
Or is it possible this would alter the properties of the CDWG...
Cut a piece of grill cloth slightly larger than the slot.  Lay the CDWG face down.  Lay the grill cloth down and push into slot with a slot length & width dowel.  Smooth it.  Glue it. Trim it.  Ta Da.  A black slot.
This will hide the not so pretty hardware but not the pretty finish.  In a living room.
I've read somewhere that the origion of the Neo Panels is defective originally but reworked for long life by Brian.  And I imagine they are planar circuit cards in construction.  That drives me nuts.  I work in a CCA factory as a Support Engineer.
I stare :o at defective CCAs all day.
I don't need them staring :o at me at  night.            :o
                                   :o                                  :o
                                   :o                                  :o
Brian Cheney
« Reply #9 on: 14 Feb 2007, 01:36 am »
While this does improve the look of the CDWG, the sound suffers.  With cloth over it the CDWG becomes noticably duller, with some dynamic compression.  Not recommended.
James Romeyn
fingerprints
« Reply #10 on: 14 Feb 2007, 03:18 am »
Best is the spray polish available at Honda mc & car dealers, black can, I'll get the exact number if requested.  Works like a charm.  Yes it has carnuba wax.
Oh, I think AH-nowd made it illegal for Honda to sell it in CA, enviornmental reasons.  Good luck.  Nice that AH-nowd still gets to drive his hummer.
Berndt
Re: fingerprints
« Reply #11 on: 14 Feb 2007, 05:56 am »
Jim, you mean honda bright?
I used that while working for big blue, they made us peel the labels off in the pits...
Sorry for the OT.
James Romeyn
« Reply #12 on: 14 Feb 2007, 08:05 am »
"Pro Honda
Spray Cleaner & Polish
Quickly Cleans, Polishes & Protects"
H/C 3597275, black can, 14oz, pink text on diagonal white stripe
If someone knows of a better all-purpose spray product for this use, please tell us.  It's a steal for only $6 or so...goes on quickly & evenly, wipes off easy
In case anyone didn't know, Big Red nose they s___t
Bill the guy who turned me onto it is Jason ______ (forgot), owner of Moto Meccanica in SRsa, duc/triumph dealer, BOTT bike builder.  If you saw the insanely huge collection of old Euro bikes & parts he has you'd not believe it...I'd love one of his race-prepped Thruxtons (new model)
