CD Sleeves that fit inside carboard CD holders
0 Members and 1 Guest are viewing this topic. Read 1101 times.
R_burke
« on: 20 Oct 2006, 05:31 pm »
I hate the cardboard "digipak" cd packages because of what I fear they do to CDs.  I have a few Japanese imports that have a inner sleeve that is made out of cloth (?) and some that have a plastic sleeve.  Both types readily fit inside of the packaging.  All of the sleeves that I have found on the internet and in stores don't fit inside the packaging because the have paper or cardboard around the outside.
Anyone know where I can find sleeves that fit inside existing CD packaging?
Steve Eddy
    • http://www.q-audio.com
Re: CD Sleeves that fit inside carboard CD holders
« Reply #1 on: 20 Oct 2006, 05:55 pm »
What are the dimensions of the sleeves that do fit?
se
R_burke
« Reply #2 on: 20 Oct 2006, 06:23 pm »
se
Just slightly bigger than a CD, ~ 5" x 5"
Steve Eddy
« Reply #3 on: 20 Oct 2006, 08:10 pm »
Ah, ok. Then these should work:
Tyvek CD Sleeves
The ones on the bottom with no flap. They're 4-7/8" x 5".
se
R_burke
« Reply #4 on: 20 Oct 2006, 09:29 pm »
Thanks, I think I will actually try the ricepaper sleeves, they are a little cheaper and it reminds me of what my high quality vinyl was packaged in  :roll:
Steve Eddy
« Reply #5 on: 20 Oct 2006, 09:54 pm »
Heheh. I know exactly what you mean.
By the way, who's selling the ricepaper sleeves? Don't recall ever coming across those back when I was looking for sleeves.
se
R_burke
« Reply #6 on: 21 Oct 2006, 06:05 am »
Same place you recommended, the're actually polyethylene (sp?) and just called Disckeeper Ricepaper sleeves, but they are only $3.00 for a hundred.  You can find them near the end of the plastic sleeve section.  The only pissy point for me is that they want $5.00 to ship the $3.00 item   :roll:
Steve Eddy
« Reply #7 on: 21 Oct 2006, 06:52 am »
Oh, ok! Thought you meant real ricepaper. :lol:
Know what you mean. Ordered a couple of brad point drill bits recently for $1.75 each. Shipping was $6.99.
se
