0 Members and 1 Guest are viewing this topic. Read 1527 times.
I just ordered the Extreme Mono Blocks with the Candela preamp to use with Eminent Tech speakers. I've decided to place the Mono Blocks close to the speakers and put the preamp and source components to the rear of the room. I will need a cable of at least 29 feet from the amp to the preamp. I understand that XLR cables are better for long runs. I was just curious if anyone out there is running a similar setup? If so, are you mixing XLR and RCA together, and with what results.
