HTBP switch box
0 Members and 1 Guest are viewing this topic. Read 1009 times.
mca
HTBP switch box
« on: 14 Oct 2006, 05:46 pm »
Does anyone know if a simple home theater bypass switcher exists? I know more manufacturers are putting this function into their preamps and integrateds. Since I am using a modded SB3 as my source, I will probably be running it straight into an amp and using the digital volume of the SB3. I am looking for an easy way to incorporate the amp into my theater setup.
JoshK
Re: HTBP switch box
« Reply #1 on: 14 Oct 2006, 06:34 pm »
You could put an A/B switch between your preamps and your amp then you could switch between your pre/pro & your SB.
mca
Re: HTBP switch box
« Reply #2 on: 15 Oct 2006, 01:24 am »
I don't use a preamp. SB3 goes direct to amp.
sleepysurf
  • Member of the Suncoast Audiophile Society
    • Suncoast Audiophile Society
Re: HTBP switch box
« Reply #3 on: 15 Oct 2006, 02:07 am »
Up until recently, I used a Niles AXP-1 rotary switch for this exact purpose, feeding my SB2 direct to my Sunfire amp, and alternatively feeding a Yamaha RX-V1000 (pre-outs) to that same amp, for home theater playback.  It sounded fine, despite the extra sets of RCA interconnects required.  However, seeking to inject some "tube magic" in my system, I recently upgraded to the Modwright SWL 9.0SE pre-amp, which includes a home theater bypass loop.  I ended up giving the Niles switch back to the audio friend who had lent it to me.  However, they are available with a street price under $75.  There are also many other (expensive) passive switches out there.
Re: HTBP switch box
« Reply #4 on: 15 Oct 2006, 08:58 am »
mca,
Just curious, have you tried adding various pre-amps to see if the sound improves with the better impedance matching?  BTW I ran mine that way, being a purist, but always wondered if...
mca
Re: HTBP switch box
« Reply #5 on: 16 Oct 2006, 02:51 am »
JLM,
I did use a tubed preamp, but have now sold it. I found the sound to be better without it. I have not tried any other preamps with it.
