DAC-AH
0 Members and 1 Guest are viewing this topic. Read 1528 times.
ryno
DAC-AH
« on: 11 Oct 2006, 10:12 pm »
I've been wanting to try a NOS-DAC for a while now. Since I've recently decided to set up a bedroom/headphone system, nows a good time. This DAC has the right size/price/inputs, and I was readt to order. But I just saw this thread on headfi:
http://www4.head-fi.org/forums/showthread.php?t=200856
Has anyone else noticed the same issues?
Ryan
trianglezerius
Re: DAC-AH
« Reply #1 on: 11 Oct 2006, 10:22 pm »
I just bought a DAC-Ah from Pacific Valve with upgraded op amps. I been burning it in and listen in once and awhile. I hear no problems with it so far. Except its awefully boomy compared to my reference CD player.
Danny Richie
Re: DAC-AH
« Reply #2 on: 11 Oct 2006, 11:01 pm »
I haven't received any such feedback regarding them.
I can't see doing any mods to the DAC-AH though. It just isn't work it. By the time you crack the top on it and do anything to it, you are easily into the price range of the DAC-72. The DAC-72 and the DAC-60 are much better units. There is nothing you can do to the DAC-AH that will bring it up to the level of a DAC-72. So I can't see throwing any money at it in that way.
