Sound quality difference between the Tanzanite and the RC3R??
0 Members and 1 Guest are viewing this topic. Read 3167 times.
Rklepl
Hi,
Could someone describe what the differences between the Tanzanite and the RC3R would be? Obviously the Tanzanite uses a better mid-woofer, but I find it interesting that the FR graph on Selah's site shows that the RC3R has much flatter response, why is that? I realize the RC3R will have slightly better bass response, but if they would be used with a subwoofer anyway (in my case), that is not an issue.
« Last Edit: 11 Oct 2006, 06:23 pm by Rklepl »
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Hi,
Thanks for your Tanzanite order  :D  With a subwoofer I usually suggest the Tanzanite sealed version. The RC3R is popular with our 2-channel customers who benefit from the extra bass extension.
Rick
Rklepl
Hi Rick,
Can't wait to test them out for sure! Am I remembering correctly that I read somewhere that the Tanzanites are being reviewed by some internet publication (a follow-up more detailed review of a shorter version done not long ago)?
I forgot to ask you too why is it that the FR graphs look so different between the Tanzanite and the RC3R in the upper frequencies?
Rick Craig
  • Selah Audio
Hi Rick,
The Tanzanite review will be in Positive Feedback's online magazine. I believe the smoothing may have been different for the two response curves. It's been awhile since I did the measurements but it looks like the Tanazanite curve is with no smoothing and the RC3R is 1/12 octave. That would account for some of the difference plus they are voiced a little different.
Rklepl
Cool, that makes sense on all counts. Thanks Rick!!
