Bryston's DACs
0 Members and 1 Guest are viewing this topic. Read 9759 times.
guest41324
  • Guest
Re: Bryston's DACs
« Reply #20 on: 4 Nov 2006, 12:53 am »
Bob Reynolds
Re: Bryston's DACs
« Reply #21 on: 6 Nov 2006, 06:19 am »
Some may want to check this thread for info on ASRC.
http://www.diyaudio.com/forums/showthread.php?s=3d0368dd3cc1a0bc53bf43bc87fffb5f&threadid=28814
Thanks for the link. I've read through the first 3 pages and very good information so far.
muski
Re: Bryston's DACs
« Reply #22 on: 10 Nov 2006, 01:10 am »
James --
A couple more questions on your upcoming DAC (or its next release)
1. Is there any kind of 'digital tape-loop' support?  I would basically like to be able to switch between multiple digital sources, send it out to a digital parametric EQ, and then have it come back to the DAC for digital to analog conversion.
2. What are your thoughts on word clock out from the DAC?
3.  For rack planning purposes, how tall do you expect your new DAC and CD transport to be?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston's DACs
« Reply #23 on: 10 Nov 2006, 10:50 pm »
James --
Hi muski,
I Do not think we will have a digital tape loop but I will check with engineering.
2.Not sure - will check.
3.The DAC and CD transport will match the BP26/MPS2
james
