Nearfield listening
0 Members and 1 Guest are viewing this topic. Read 1480 times.
Spirit
Nearfield listening
« on: 9 Oct 2006, 03:31 am »
Can someone please define the term, comment on pros/cons, and variables
for proper set up.
bprice2
Re: Nearfield listening
« Reply #1 on: 9 Oct 2006, 03:42 am »
Spirit
« Reply #2 on: 9 Oct 2006, 03:48 am »
Maybe this will help.
http://www.audiocircle.com/index.php?topic=31627.0
Thanks B
That was fast.
BTW, was there a bprice1?
bprice2
« Reply #3 on: 9 Oct 2006, 04:11 am »
Actually, when I first registered I used the first part of my e-mail address.  I thought it would be easy to remember when signing on, but not realizing it would be my screen name.  That's it...here I am...bprice2.  Not very catchy.
« Reply #4 on: 9 Oct 2006, 09:42 am »
My serious listening is nearfield (68 inch equilateral triangle) with my computer chair about 5 feet behind.  Speakers are toed in to cross between those two positions.  Speakers are over 5 feet from front wall and 3 feet from side walls (Cardias recommended setup).  As mentioned above I wouldn't try it with complicated speakers designs or those using high slope crossovers.
When sitting in "the" chair even kids have instantly commented on the magic.  Their eyes light up in amazement.  As Casler mentioned it takes you from hearing the performance in the room (normal set up) to being at the performance (nearfield).  The first impression is that it sounds too much like headphones and large speakers like mine look silly/scary close.  But the soundscape coherence is amazing.
Unfortunately modern recording technics are miked too close, so you can get too much of a good thing.  It does help take the room out of the equation, but IMO the best listening room would be very large.
Frihed91
Right
« Reply #5 on: 9 Oct 2006, 09:52 am »
Each room is different.  You want to get your speakers as far away from the rear and side walls (unless they are corner lovers) to get rid of the evil reverbs, esp if you have rear firing speaker sports.  But what if that puts your speakers 4 feet away from the front wall and the speakers are now 1 foot apart?  Well, obviously you have to compromise.  You always do.  Use whatever toe-in sounds best.  Experiment.  That's the key with getting the best speaker position in a "real" room anyway.  And keep the volume at low to moderate levels.  This cuts down on first reflections.
Tuck the speakers back into some wife friendly place when you are not listening or she is around!
