16/44.1 output from Offramp Turbo without loosing 'locking' in upsampler
0 Members and 1 Guest are viewing this topic. Read 2364 times.
Anders
Hello,
I have purchased an Offramp Turbo and a battery power supply (used).
I run 16/44.1 WAV-files into Offramp Turbo and have selected Operating Mode
"2 in, 2 out, 16-bit, 8000 Hz to 48000 Hz" in the M-Audio Transit USB Application.
Version of the software is 5.10.00.54 for ASIO and USB. Firmware version is 1.00.
The output are going into an upsampler, dCS Purcell, that again
are sending it to the DAC dCS Delius.
The problem is that when starting every song, the upsampler seems
to loose the locking on the signal from Offramp Turbo.
And a new locking on the signal must be done,
resulting in loosing 3-5 seconds in the beginning of every song.
But this problem is not occuring when setting output signal from
Offramp Turbo to 24/96.
I am very happy if someone have a solution/workaround on this problem.
Anders
audioengr
Are you using Foobar?
Is it set for 16-bit and no upsampling in Preferences?
Are you also using ASIO plug-in?
I've never had this problem. Usually only the WiFi converters stop between songs.
Steve N.
Anders
Hello again,
thank for answear.
I now get it running by running foobar version 0.8.3 with asio plugin 048a.
I will try to run it with Musicmatch Juxebox.
When I figured out how to use asio plugin with it.
Anders
Anders
I see that Musicmatch Jukebox don't have support for ASIO :-(
But both Winamp and jriver Media Center has support.
I think I will check these out.
Maybe I will see that foobar is the best alternative :-)
Anders
