New!! Slim Devices Transporter High Performance Mods/Rebuilds!!
0 Members and 1 Guest are viewing this topic. Read 2862 times.
Reference Audio Mods
    • http://www.referenceaudiomods.com
Slim Devices Transporter High Performance Modifications/Rebuilds Inquiries:
WorldWide Service:
Doug Jesse RAM East (Warren, Michigan)
[email protected]
phone (586)944-5611
Kyle Takenaga RAM West (Riverside, California)
[email protected]
phone (951)780-2869
The Transporter has worldwide voltage capabalities and we can work on transporters that can be dropped shipped in for mods, or you can send us your transporter from anywhere
in the world. We will adjust and add the extra international shipping fees into the price, please email for quote.
Introduction :
Slim Devices has come out with their best product yet, the Transporter. This is the highest end music streamer they offer and it uses very good electronic topologies in comparsion to their competitors products.This is a great platform to modify from and be able to produce world class sound from your music file collection. Reference Audio Mods has now stepped up to the plate to bring the industrys first available high performance modifications and rebuilds to this great product. If you are listening to a stock transporter, you are missing so much! We have developed 3 different mod/rebuild packages to suit all budgets.  Extract the most sound from your transporter!
Modification Packages and Descriptions:
"Budget Modification Package ($595 Installed/Shipped)
Designed for audiophiles on a budget who want better performance than the stock unit. This is basically a "parts swap" upgrade and well worth it. Eliminates the glare and grain and improves soundstaging, resolution/dynamics and clarity. Only recommended if the $995 or $1395 is out of your budget (we can upgrade you to those mods if you decide to get this mod package for the price difference between the packages).
Power Supply mods-
Add Furutech IEC Connector, Replace stock noisy diodes with RAM Ultra Low Impedance Handmade Diode Bridge, Replace an abundance Voltage rail capacitors with Ultra Low Impedance Rubycon ZA/ZL caps in power supply and for analog
decoupling.
Analog Output mods-
Replace ALL Analog output stage opamps from the gritty sounding 5534's to the Analog Devices AD825 opamps for a drastic change in performance. Replace coupling and voltage rail caps with Ultra Low Impedance Rubycon ZA caps, Replace stock RCA's w/WBT Copper NextGen and wire into circuit with Audio Consulting Silver Wire/Cotton tubing.
"Advanced Modification/Rebuild Package ($995 Installed/Shipped)
Designed for audiophiles who are serious and have the budget to really excel the transporter to a much further level thats beyond their expectations. This level mods removes the entire Analog output stage and adds the Audio Consulting Copper wire signal coupling transformer stage. This eliminates ALL resistors, capacitors, opamps, transistors, etc.. Pure as possible! No signal deteriotating parts! Absolute huge step forward. Eliminates the glare and grain and drastically improves soundstaging, resolution/dynamics and
clarity.
Power Supply mods-
Add Furutech IEC Connector, Replace stock noisy diodes with RAM Ultra Low Impedance Handmade Diode Bridge, Replace an abundance Voltage rail capacitors with Ultra Low Impedance Rubycon ZA/ZL caps in power supply and for analog decoupling.
Analog Output mods/rebuilds-
Completely remove the entire Slim devices analog output stage, Add Audio Consulting Copper Wired Signal Coupling Transformers. Wired to both XLR and upgraded WBT Nextgen RCA connectors.
True Balance Output now! Eliminates ALL opamps, ALL resistors, ALL signal capacitors, All transistors, etc.
A complete and drastic step forward. Soundstage widens/deepens significantly. Inner resolution and fine details are evident like never heard before. This will be a rediscovery to your music collection. All voltage rail caps for the AKM DAC Chip are replaced with Ultra Low Impedance Rubycon ZA caps. Replace stock RCA's w/WBT Copper NextGen and wire into circuit with Audio Consulting Silver Wire/Cotton tubing.
"Premium Modification/Rebuild Package ($1395 Installed/Shipped)
Designed for audiophiles who are ultra serious and have the budget to bring the transporter to levels thats beyond their expectations. This level mods removes the entire Analog output stage and adds the Audio Consulting Silver wire signal coupling transformer stage and removes the stock super regulator circuit and replaces it will the Audiocom PPR2 Ultra High performance discrete voltage regulation circuit. Absolute huge step forward. Eliminates the glare and grain and drastically improves soundstaging, resolution/dynamics and clarity.
Power Supply mods-
decoupling. Replace the stock Super Regulator circuit with the Audiocom PPR2 Ultra High performance discrete voltage regulation circuit for even far less noise and tigher voltage regulation to improve the music.
Completely remove the entire Slim devices analog output stage, Add Audio Consulting Silver Wired Signal Coupling Transformers. Wired to both XLR and upgraded WBT Nextgen RCA connectors.
A complete and drastic step forward. Soundstage widens/deepens significantly. Inner resolution and fine details are evident like never heard before. This will be a rediscovery to your music collection. All voltage rail caps for the AKM DAC Chip are replaced with Ultra Low Impedance Rubycon ZA caps. Replace stock RCA's w/WBT Silver NextGen and wire into
Click below for more info and Ordering:
http://www.referenceaudiomods.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=SDTransporter&Category_Code=MODS&Product_Count=44
We accept ALL forms of payment. You can also have new units drop shipped in. We will work on any unit in the world and will add the international shipping on the cost of the mods.
« Last Edit: 3 Oct 2006, 11:04 pm by Reference Audio Mods »
Wayne1
Quote from: Reference Audio Mods
Analog Output mods-
Replace ALL Analog output stage opamps from the gritty sounding 5532's to the Analog Devices AD826 opamps for a drastic change in performance. Replace coupling and voltage rail caps with Ultra Low Impedance Rubycon ZA caps, Replace stock RCA's w/WBT Copper NextGen and wire into circuit with Audio Consulting Silver Wire/Cotton tubing.
You may want to check the Transporter a bit more carefully.
The output section uses 5534 op-amps in it. Those are single op-amps.
I believe if you replace them with AD826s, which are a dual op-amp, you will get more than "a drastic change".
yeah I get those mixed up because I always bypass them. it has 5534's and the replacement is AD825 I'll fix that. thanks for noticing the typo.
