0 Members and 1 Guest are viewing this topic. Read 4101 times.
I will be using my GR Research Paradox 3s that have only two binding posts per speaker. Will I be hooking up one set of speaker wires to the left channel on one amp and the other set to the other amp? I don't know why this is so confusing to me
Am purchasing an Arcam A-85 integrated that has the option of me adding an external amp for bi-amping purposes. If at a future date I decide to add another amp, do I need to purchase the exact same power specs (85 wpc) of the Arcam or can I use any power amp? Say I added a 105 wpc amp to the Arcam; Will the output to my speakers then be 190 wpc into each speaker? I will be using my GR Research Paradox 3s that have only two binding posts per speaker. Will I be hooking up one set of speaker wires to the left channel on one amp and the other set to the other amp? I don't know why this is so confusing to me
Eric,Do not hook two power amps together to the same speaker terminals, you will blow your amps and speakers up. For you to bi-amp, or bi-wire you need speakers that have two sets of speaker inputs, one for the low frequency driver(s), one for the high frequency driver(s). In these types of speakers, there isn't any internal connections between the two sets of binding posts. Usually these speakers have an external strap or wire connecting the commons together and the hots together for use with a single amplifier. If you are going to bi-amp with one amplifier driving each speaker, you must have identical amplifiers as their gain will be identical.W
With one pair of binding posts per speaker......you cannot bi-amp......period.....end of story! Nor can you bi-wire.jeeez! do some research and learn what bi-amping and bi-wiring is!
I'm trying to do my research NOW with these questions. A reviewer of the amp in question said this " There's also a power-in/pre-out loop for driving an external amplifier for biamping applications", thus my questions. IF MY QUESTIONS ARE TOO DUMB ASS FOR YOU, STAY OUT OF THE DISCUSSION.
Quote from: eric the red on 3 Oct 2006, 04:47 pmI'm trying to do my research NOW with these questions. A reviewer of the amp in question said this " There's also a power-in/pre-out loop for driving an external amplifier for biamping applications", thus my questions. IF MY QUESTIONS ARE TOO DUMB ASS FOR YOU, STAY OUT OF THE DISCUSSION.OK.....let me decipher.(1) The integrated under question has a "power in". This means you can by-pass its line section, and only use its amp section. You would need to use an external line stage to do this.(2) It also has a "pre out". This means you can use the integrated's line section only, and then run the signal into another stereo amp...should you choose to do so. It also allows for bi-amping, since you can route the signal to another amp, and the signal will also be at the internal amp's outputs....hence 2 stereo amps with the same L and R signal in each amp.One way to biamp would be the following:Use one stereo amp , L and R channels, to drive the L and R woofer.Use the other stereo amp, L and R channels, to drive L and R tweeter.Additional gear required to bi-amp:* amp* interconnect* speaker cables* separate volume pot (to control gain differences if amps have different input sensitivities)Just because you have the ability to send the signal to another amp, does not mean you can bi-amp.To do so, your speakers must have 2 pair of binding posts.I answered your questions directly and with 100% accuracy.As have several others.The frustration is...you keep asking the same thing over and over and over, even after it has been satisfactorily answered. Others are making the time and effort to help. Your need for spoon-feeding suggests that your effort is minimal. Stop wasting bandwith.
Quote from: toobluvr on 3 Oct 2006, 09:43 pmQuote from: eric the red on 3 Oct 2006, 04:47 pmI'm trying to do my research NOW with these questions. A reviewer of the amp in question said this " There's also a power-in/pre-out loop for driving an external amplifier for biamping applications", thus my questions. IF MY QUESTIONS ARE TOO DUMB ASS FOR YOU, STAY OUT OF THE DISCUSSION.OK.....let me decipher.(1) The integrated under question has a "power in". This means you can by-pass its line section, and only use its amp section. You would need to use an external line stage to do this.(2) It also has a "pre out". This means you can use the integrated's line section only, and then run the signal into another stereo amp...should you choose to do so. It also allows for bi-amping, since you can route the signal to another amp, and the signal will also be at the internal amp's outputs....hence 2 stereo amps with the same L and R signal in each amp.One way to biamp would be the following:Use one stereo amp , L and R channels, to drive the L and R woofer.Use the other stereo amp, L and R channels, to drive L and R tweeter.Additional gear required to bi-amp:* amp* interconnect* speaker cables* separate volume pot (to control gain differences if amps have different input sensitivities)Just because you have the ability to send the signal to another amp, does not mean you can bi-amp.To do so, your speakers must have 2 pair of binding posts.I answered your questions directly and with 100% accuracy.As have several others.The frustration is...you keep asking the same thing over and over and over, even after it has been satisfactorily answered. Others are making the time and effort to help. Your need for spoon-feeding suggests that your effort is minimal. Stop wasting bandwith.
And thanks to everyone who did try and help me understand this. Cya
This site used to be a cool place to ask questions about all things audio but now it's not with wankers like you two on board. Hey Zybar and Tooblur: Ever heard the term "Go fuck yourselves"? I'll bet at least one of you have. ETR logging off for the last time.
