New Maggies, power amp question
0 Members and 1 Guest are viewing this topic. Read 1626 times.
George
    • spydernation
« on: 2 Oct 2006, 06:51 pm »
I recently bought a new pair of Magnepan 1.6s from Audio Advice in Raleigh, NC. When I asked about upgrading from my current Rotel amp, they unhesitatingly said "Bryston".
I have read and read and read on ye olde internets, and I believe I have come to the conclusion that (as always) the boys at Audio Advice know their business. So my question is, given my "across the front" line-up of Magnepan 1.6s and a Magnepan MGCC-1 center, do I want to go with the 9B SST (I have a pair of Mirage 190i in the rear) or do I want to get really serious up front and go with 6B SST and just use the old Rotel to drive the rears?
Your opinions are both desired and welcome.
  • The Demo is Everything!
    • http://www.bryston.com
Re: New Maggies, power amp question
« Reply #1 on: 2 Oct 2006, 08:40 pm »
Hi George,
I have owned every Maggie there is to own and my advice is go BIG on the fronts.
A 6B (LCR) and the Rotel (LR RR) or a 4B (left and right) and a 3-channel 9B for the Center and Surrounds.
james
George
    • spydernation
« Reply #2 on: 2 Oct 2006, 09:02 pm »
Hi George,
I have owned every Maggie there is to own ....
Okay, you have my curiosity piqued. What are you running now?
Thanks for the recommendations.
« Reply #3 on: 2 Oct 2006, 10:21 pm »
I am now using PMC's.
james
john1970
« Reply #4 on: 2 Oct 2006, 11:47 pm »
George,
I recently purchased a Bryston 4B SST for a two-channel audio system.  My speakers are VMPS RM40s.  They are relatively efficient at 90dB/1W/1m, but they are a true 4 ohm speaker (min = 3.5 and max = 4.5).  IMO I would go with the 4B SST for the main speakers and a 3 channel 9B SST for the center and rear.  With this setup if you ever decide to go to a 7 channel system you can add two additional channels to the 9B.
Best,
John
