I've been out of the loop for a bit.... Any news on SP2 software updates?
0 Members and 1 Guest are viewing this topic. Read 2292 times.
nicolasb
I've so far not bothered to look into getting my SP1.7 upgraded to an SP2, as the differences between the two models do not (from my particular perspective at this particular time) seem to justify the cost of the upgrade. But I'm very interested in some of the possible future software upgrades to the SP2 that were being discussed a few months back, and certainly would upgrade if they became available. So, is there any recent news on when (or, indeed, if) we'll be seeing parametric EQ on the SP2? And any chance of Dolby Headphone output?
  • The Demo is Everything!
    • http://www.bryston.com
Hi nicolasb,
We have not even looked at the EQ option yet so I would say we are a least 6 months away.
james
MOZ
Nicolasb,
The upgrade is quite significant to me  :green:
You get a faster, smoother, more detailed and "easier and more powerful" preamp on the digital way, with great software updates (THX Ultra 2 !)...
It changes a LOT of things with movies... and even multichannel audio !
sikoniko
The dealer I took my sp2 to said after giving it a go that it was a night and day difference.
nicolasb
I dare say, but my cash supply is a lot more restricted now than it used to be. :(
Plus, although I must confess I haven't checked with PMC, I suspect the upgrade cost will be a lot higher in the UK than it is in North America.
James T, has Bryston actually ever seriously considered enabling Dolby Headphone output on the SP2? I know it's part of the standard software library for the Aureus chip so, on the face of it, it ought not to be as difficult to add (in software-only form) as some other things would be.
Hi,
We have not looked at D headphones at this point.
james
alpsy
what's the latest firmware version for the sp2?
james, perhaps you could tell me when the latest version was first factory loaded into the sp2 (serial number would be helpful)
cheers,
julie
madders
Where do I find out the cost of upgrading an SP1.7 to SP2 in the UK?
Hi Steve,
Just PMC.
james
madders
Thanks James  :D
