sp-2 12 volt trigger
0 Members and 1 Guest are viewing this topic. Read 1212 times.
juan-paco
« on: 2 Oct 2006, 04:35 am »
Can anyone explain to me exactly how to wire my 4bsst and 300sst powerpac to my sp2's 12-volt trigger properly.  The instuctions in the sp2 manual in regards to this are a bit confusing. Please help!  I'm really getting tired of manually turning on and off my amps.  Thanks.
brucek
Re: sp-2 12 volt trigger
« Reply #1 on: 2 Oct 2006, 12:56 pm »
What exactly is the problem? Are you having trouble programming the AUX output or do you not understand the wiring.
To disregard a trigger that comes on for a specific device ("AUX output") and simply use a trigger that comes on all the time when the SP2 is powered up, use the "C" common output and the ""ON/OFF" output.
Use any two wire cable(s) and connect it to the device(s) you want to trigger on...
brucek
jethro
« Reply #2 on: 2 Oct 2006, 08:56 pm »
Don't forget the Local/Auto switch on the back of the 4B-SST (and probably a similar switch on the powerpak).
juan-paco
« Reply #3 on: 2 Oct 2006, 10:13 pm »
Thank you both very much for your responses.  I had the switch on the 4bsst set to local instead of external.  When I switched to external, "presto", everything is wonderful again. Thanks again, John
