0 Members and 1 Guest are viewing this topic. Read 6333 times.
There is a further significant issue here - when it comes to interfacing with the power amplifier, for best performance, the input and feddback impedances should be (approximately at least) matched so that the input stage can function properly. If the feedback impedance seen by the input stage is ~ 1K ohm, then a 50K pot at the input is a serious imbalance.
...even though the input impedance of an amplifier, commonly defined by the input biassing resistor, may be 20K -> 100K this is not carte blancheto drive it from a 2K - 10K source. The drive impedance should match the feedback impedance.
you would want amp input impedance to be at least ten times the source output impedance
Why do you keep saying that the source inpedance at the input should match (or be fairly close to) the impedance of the feedback circuit?The lower the impedance of the source the better.
Wouldn't matter much if you're a flat earther, a differential stage is balanced by equal source impedances at both inputs, irrespective of FB.
