Power Supply, sub 200$, 220VAC
0 Members and 1 Guest are viewing this topic. Read 2176 times.
niknik
« on: 30 Sep 2006, 10:50 pm »
I'm looking into which Power Supply to choose for my coming SB2.
I need 220VAC -so no ELPAC
As much as I flirt with getting the Ultimate MKII my budget doesn't allow me to do this for now. I am looking at what is possible for under 200$
I have found 3 which I think can be used?
Power One:
http://www.audiocircle.com/index.php?topic=30362.0
Welborne PSREGHC:
http://www.welbornelabs.com/psreghc.htm
Lambda:
http://rswww.com
Part number: 173-1604
I see that Wayne does a mod on the Power One..
Have you experience with the other two? Would you offer a mod to one of the others too? (Wayne?)
What would be the best choice for me?
Regards
/Nik
Wayne1
Re: Power Supply, sub 200$, 220VAC
« Reply #1 on: 2 Oct 2006, 02:47 pm »
Nik,
The Welborne is probably the best choice, if you do not have a problem building a case for it.
I think Ron has chosen some good parts. It is not as good as the Ultimate  :wink: but it is a lot cheaper.
niknik
« Reply #2 on: 2 Oct 2006, 11:00 pm »
Thanks Wayne
I think I'll give the Welborne a try -seems they do some quality stuff.
The Ultimate is not for me (my wallet) right now..  :deadhorse:
 8)
