Plitron transformer for AKSA 100w
0 Members and 1 Guest are viewing this topic. Read 1892 times.
Martyn
« on: 29 Sep 2006, 05:41 am »
Since Hugh's website is down at present, will someone kindly tell me the part number for the Plitron toroidal transformers for the AKSA 100? Thanks,
Martyn
AKSA
Re: Plitron transformer for AKSA 100w
« Reply #1 on: 29 Sep 2006, 07:06 am »
Hi Martyn,
The Plitron number is 077019201, rated at 300VA with  33-00-33 Vac 4.55A secondaries.
Website is back up now!!
Greg Erskine
« Reply #2 on: 29 Sep 2006, 08:31 am »
No its not  :duh:
AKSA
« Reply #3 on: 29 Sep 2006, 08:35 am »
Greg,
You sure??  Try This Site
Greg Erskine
« Reply #4 on: 29 Sep 2006, 11:36 am »
Hugh,
Seems to work now, yesterday and earlier this afternoon I was getting domain errors. Probably just a cache issue.  :oops:
regards
Martyn
« Reply #5 on: 29 Sep 2006, 02:48 pm »
Thanks, Hugh.
Last night your website was still inaccessible. I've just checked again this morning and it's now back up.
AKSA
« Reply #6 on: 29 Sep 2006, 11:42 pm »
Thanks Greg, Martyn,
Apparently when you change nameservers, the lookup information which links the text with the IP address takes a couple of days to cascade down to the various hub servers around the world.  Until all share the same lookup table, the access will be patchy.
Interesting, this internet, huh?
Hugh
