Buying fuse for Plinius 9200? where ?
0 Members and 1 Guest are viewing this topic. Read 2210 times.
michaelv
« on: 26 Sep 2006, 05:45 pm »
Hi,
 I'm looking to buy extra fuse for the integrated amp Plinius 9200 (Rail fuses for 9200/P8/P10
Set of four 7.5A fuses for Plinius 9200, P8, and P10 ... )  Do I have to buy a brand name or just any rail fuse that is the same ampere?  IF so, where should i buy it? I'll try radioshack first ...
thanks.
Glen B
Re: Buying fuse for Plinius 9200? where ?
« Reply #1 on: 26 Sep 2006, 07:25 pm »
Are they fast acting or slow-blow and what voltage rating ?   Check out Digi-Key Corp.
http://www.digikey.com/scripts/DkSearch/dksus.dll?Criteria?Ref=338632&Site=US&Cat=35062567
michaelv
« Reply #2 on: 26 Sep 2006, 08:35 pm »
Thanks.
 The label on the fuse bag states that it's normal blow. I'm not sure about the voltage, by the way.
Doublej
« Reply #3 on: 26 Sep 2006, 08:43 pm »
Assuming you are in the US you can get them directly from
http://www.eliteavdist.com/
which is the US distributor of Plinius.
IMHO it's the easiest and most cost effective way.
