Quick question about insulation material inside the AV kit?
0 Members and 1 Guest are viewing this topic. Read 1346 times.
Loftprojection
OK, now I have to push in some pink insulation material inside my AV3s box.  I've got Blackhole on all the walls.  So my question is how much of the pink insulation do I add in there.  Do I kind of push some in with a pit of pressure to "compress" it in a bit or do I just push some in so that it fills everything but very very loose?
Thanks.
Danny Richie
Re: Quick question about insulation material inside the AV kit?
« Reply #1 on: 23 Sep 2006, 05:39 pm »
Since you already have BH-5 in there, then a loose fill will be fine.
Loftprojection
« Reply #2 on: 25 Sep 2006, 11:16 am »
Good, thank you Danny!
