Norah Jones: CD or SACD hybrid?
0 Members and 1 Guest are viewing this topic. Read 1114 times.
michaelv
« on: 20 Sep 2006, 11:36 pm »
Hi,
  Have you ever listened to Norah Jones in both formats: regulare CD and SACD hybrid (2 channels portion)? Which one do you prefer in term of sound quality?
thanks.
fajimr
Re: Norah Jones: CD or SACD hybrid?
« Reply #1 on: 20 Sep 2006, 11:44 pm »
which album?
I actually thought they were both pretty good on regular CD but haven't compared to SACD.
michaelv
« Reply #2 on: 20 Sep 2006, 11:50 pm »
Come Away with me
SWG255
« Reply #3 on: 21 Sep 2006, 12:01 am »
This topic raised some contraversy awhile back because Blue note admitted that they cut the SACD from a PCM "master". SACD die-hards will insist that this will compromise the sonics of the disc. I have both the redbook CD and the SACD hybrid and prefer the sound of the SACd, but not by a signifigant margin. I believe the difference has to do with the player, and as my Sony SCD-1 has gone through a series of modifications that improved both redbook and SACD playback, the sonic difference between the two discs narrowed. If you have a good redbook player, the difference probably won't be worht buying the SACd for. If you feel your SACD playback is always better than your redbook playback, then I'd probably spring for the SACD.
Come Away with me
michaelv
« Reply #4 on: 21 Sep 2006, 12:03 am »
I don't have SACD player, just a redbook CD. So, i guess i will go with regular CD then.
thanks.
