RMS Power 100W
0 Members and 1 Guest are viewing this topic. Read 1575 times.
gypsums
RMS Power 100W
« on: 20 Sep 2006, 06:59 pm »
i know i am being a bit dense but with the nuforce does this power mean per power amp i.e if they were an intergrated would it have 200w of power??? if a speaker is quoted to have a power handling of 200w the 8.02 would be able to drive them?
nuforce-casey
Re: RMS Power 100W
« Reply #1 on: 20 Sep 2006, 10:56 pm »
Yes, the Nuforce power rating is per mono amp.  Typically, manufacturers rating their stereo amp could rate them at different ratings.  For example,a 1-channel fully driven to 100W amp can have as small as a 100W power supply, but for a 2-channel fully driven to 100W amp, it would need a 200W capable power supply.  Unfortunately, not every manufacturer make this clear.
This is really not a fully 'qualified' spec.  Either it means that the speaker could be driven continuously at 200W, or the speaker blows up as soon as the power exceeded 200W.  We suggest checking with the speaker manufacturer to make sure.
gypsums
Re: RMS Power 100W
« Reply #2 on: 21 Sep 2006, 02:48 pm »
thanks for the info this gives me more detail into speaker choice
