Here is the picture of the DAC main board with its separate power supplies
Busy with the new dac and the active preamp and stuff,
Here is the picture of the main board without the nickel pulse trans and output trans and power trans
There are 3 gain settings for these
1.25 volts, 2.2 volts and 4 volts
This way you can up the gain if your power amp has insuffice gain or lower the gain if you have too much.
Needed to add this flexibility to allow users to fine tune their gain structure without resorting to attenuators for the signal.
On the price for now its is going to be set at USD340+shipping. Weights about the same weight as the TVC.
Will post more pictures once i put all the trans together
Forgetten to mention, the DAC as its own asyn reclocking to 100Mhz. The Clock is place at the bottom of the pcb. Its is located at the bottom left of the PCB
