bugle power caps
0 Members and 1 Guest are viewing this topic. Read 1650 times.
mantisory
    • My Blog
bugle power caps
« on: 18 Sep 2006, 10:45 pm »
Hi there,
Just finished my power supply for the bugle and am wondering: can i just remove c7,8,10,11 and leave the switch on (I put a switch on the PS)?
If so, how much of the battery 'wings' can i chop off safely?
Any help would be appreciated.
Mantisory
hagtech
Re: bugle power caps
« Reply #1 on: 19 Sep 2006, 04:45 am »
You can remove C7 and C8.  Bypass the Bugle power switch with jumpers (I think there is a drawing in the PowerSupply manual).
Remove all of the battery wings.  All the way up to the outlines of the EQ capacitors.  Sometimes it helps to leave a little extra to drill a mounting hole.
jh
mantisory
    • My Blog
« Reply #2 on: 19 Sep 2006, 11:14 am »
i'm assuming you mean c7 and c10, right?
Mantisory
hagtech
« Reply #3 on: 19 Sep 2006, 11:28 pm »
Um, whatever the electrolytics are.  They come off when you chop the battery wings.
jh
