I am thinking that the type of musical presentation you get also depends on SET output impedance, speaker Qts, speaker impedance vs freq, cabinet design, and damping requirements vs freq. I am no audio boffin, so I could be well of track...Yes, sorry to imply that power, dynamic headroom, etc. are the answer -- they're not, they're just a part of it... probably.I believe that our Newtonian approach to science in general leads us to put much more stock in our overly simple models of how things work and thus we expect them to predict outcomes based on measurements made with instruments based on these same models. Ohm's law, etc. are fine for calculating approximate real-world behaviors, but reality is far more complex than our overly simplistic models can even begin to predict.I still have so many formally trained colleagues who swear that there is no possible way that different pieces of wire can sound different from each other -- wire is wire, and that is that. -- but the reality of it is that there *are* differences even if our working models can't tell us why yet. I do find it rather funny that none of these people will come over and let me switch a number of different speaker cables and ICs in and out of my system to let them hear the difference. In the speaker cable category alone I have had everything from a pair of DIY $30 cat-5 cables all the way to a $5,500 pair of Acapella Silverkables, and the difference is immediate and unmistakeable. Note that I do not in general think higher price necessarily means better performance because there are some incredible sounding cheap cables, and some lousy sounding expensive ones (just to be clear on that.)So, I guess what I'm saying, and it's the same thing I think we're all saying, is that that there are combinations that work better than others (i.e., the importance of overall system synergy) and there is really no predicting that from numbers we measure with our very simplistic test equipment. Heisenberg, where are you when I need you?Yes, the human ear and brain are far more sophisticated instruments than anything on anybody's test bench, and they are the ultimate arbiter anyway (at least as far as they convey the information to the mind for deeper processing. .)As one famous quantum physicist said to one of his classes, "Half of what we're teaching you is wrong -- we just don't know which half."The 104dB sensitive spk may have had some honking driver with a lot of impedance variation, shoved in a BR, and crossed over using some complex contrivance. Maybe it was being used in a huuuuge room. Maybe it was played at a volume considered for most of us. Maybe it needs that volume / power to sound alive and dynamic just overcome x-over inertia. Maybe the amp power meters were calibrated on the generous side for WOW factor... I don't think conclusions can be drawn from the info provided.The Klipsch K-Horn is a monster with a 15" woofer in a corner horn box (the driver is not exposed to the eye anywhere) and has a compression mid and tweeter and one huge mess of a crossover. So yes, this all adds up and partially attempts to explain the things I saw and heard. Hey, it was over 30 years ago too .In the end, I trust one thing, and one thing only -- my ears -- not merely as the physical instrument, but as the conduit to the emotional processing centers that exist somewhere between the brain and consciousness... but really, I just love to listen to good music... really.You'll have to excuse me, I'm in transition as I withdraw from an overdose of audiophilia nervosa so please be patient with me as I relearn the differences between sound and music, and obsession and passion.-- Jim
