0 Members and 1 Guest are viewing this topic. Read 32850 times.
Once one's audio is operating on the very high level of an SET and single driver speaker combination, the INTELLIGENCE of the music can be released... the inner-dimension of that intelligenceis released and it is this sense of that intelligence that allows us to make a connection with the INTENT of the musicians and/or composers... no matter what form they are "speaking" in ~
Hi Toobwacky ~I hope this doesn't sound a bit simplistic... but is your question based on the fact that you do notcurrently have a tube amp and so you are curious as to which tube amp would work best withyour XRS Omega speakers?I am asking that question because by your AC name, Toobwacky, I would have guessed that youare somewhat ga ga over tubes (Deb and I certainly are) and so would have a few varieties of tubeamps around that you could use to test for an appropriate synergy with your XRS's ~ Warm Regards ~ Richard ~
"Can anybody share some general thoughts on the Fostex impedance interaction with a tube amp?"
a small but sensitive group of cognoscente that understand the magicof a well executed SET and single-driver-wide-range speakers... simplicity is not yet a paradigm that has currency in our society... we are a society that is still in the throes of guzzling billions of gallons of oil per day and think nothing of continuing the philosophy that the earth has abundant resources to fill our insatiable appetites for "the more"... and so we apply that thinkingto everything... including audio ~
Greater current, better speaker control, higher damping factor of solid state amps and push pull tube amps, all lend themselves to your observation.
