0 Members and 1 Guest are viewing this topic. Read 8378 times.
(dipole tweeters aren't really recommended anyway).
Also, it's safe to cross rather low (~1.5-1.7k), which is a good thing for an MTM.
Quote from: gitarretyp on 14 Sep 2006, 03:17 pm(dipole tweeters aren't really recommended anyway).Given the Orion & the NaO - 2 very respected designs - use cone tweeters and are dipoles, I wonder why you say that? To say nothing of the famous Maggie ribbon? Quote from: gitarretyp on 14 Sep 2006, 03:17 pmAlso, it's safe to cross rather low (~1.5-1.7k), which is a good thing for an MTM.Can you explain why crossing low is good for an MTM configuration? What's the problem with crossing over at, say, 2.5/2.6Khz? Regards,Andy
Thanks, gitarretyp,Your definition of a "dipole tweeter" seems to be one where sound comes out the back as well as the front ... am I correct? (whereas I was thinking that a "conventional" tweeter mounted on an OB qualified! )If so ... then, yes, the Orion & the NaO are using conventional tweeters. But the Maggie ribbon is a true dipole ... so why do you regard this as "not really recommended"? Maggie HF is regarded as some of the best, period!
