Signature 3S
0 Members and 1 Guest are viewing this topic. Read 2099 times.
bprice2
Signature 3S
« on: 11 Sep 2006, 09:41 pm »
Hi Vinnie,
I've been curious about your soon to be offering of the Signature 3S.  Your link on the new website says that it will have 3 or more inputs and 2 outs.
a) Is the above statement correct?
b) Will the two outputs output together?  In other words, will you have the option of outputting to two different amps at the same time?
Vinnie, thanks again & sorry about the nu bee questions.
Brett
Vinnie R.
    • http://www.vinnierossi.com
Re: Signature 3S
« Reply #1 on: 11 Sep 2006, 11:05 pm »
Hi Vinnie,
Brett
Hi Brett,
The final details of the Signature 3S are listed here:
http://www.audiocircle.com/index.php?topic=30687.0
Here it is, copied and pasted:
The Signature 3S (Source Select Switch) – This is still in the works and is definitely going to happen soon enough.  As with the Signature 30 am in the process of switching to a different enclosure manufacturer.  This has been the main cause of delay.  I anticipate that the Signature 3S will be ready in October 2006.  Here are the final details:
-- Matching enclosure and machined aluminum knob as the Signature 30, but will have “Signature 3S” laser engraved instead of “Signature 30,” and the rear panel will have Vampire RCA jacks (as the Signature 30s now have) for the inputs and outputs.  No LED on the front because this is an entirely passive switch….very simple, very clean.
-- There will be 4 inputs and 1 output
-- The input select switch used will be the DACT CT3: http://www.dact.com/html/input_selectors.html
-- Same internal wiring as the Signature 30 -- solid-core, OCC processed copper with mono-crystal design and hybrid (PVC/Teflon, Nylon) jacket.
-- The price will be $399.00.
Best regards,
Vinnie
bprice2
Re: Signature 3S
« Reply #2 on: 12 Sep 2006, 03:29 pm »
Ok...but your new website says its 3 or more inputs and 2 outputs (its under the "News" link).  You might want correct that so as not to confuse.  Sounds like you're pretty set with the box only having one out.  It would be nice to be able to run to another amp for my outside deck speakers.
Vinnie R.
Re: Signature 3S
« Reply #3 on: 12 Sep 2006, 07:34 pm »
Hi Brett,
Thanks for spotting that error and I'll have it fixed.
Best regards,
Vinnie
