SB3 Analog Mods Customized?
0 Members and 1 Guest are viewing this topic. Read 1572 times.
BrassEar
« on: 11 Sep 2006, 06:56 pm »
Hi Wayne.
Interested in the SB3 analog mod but I have a few questions:
1. I love the sound of oil caps and I have a set of 10 mfd oilers. Can you do the analog mods and use the caps I provide with the unit? They are very large and would have to be installed outside the unit.
2. What is the current turnaround time for this mod?
Wayne1
Re: SB3 Analog Mods Customized?
« Reply #1 on: 11 Sep 2006, 07:29 pm »
10 ufd PIO? They must be about the size of the SB3 alone  :lol:
Unfortunately running wire outside the chassis is just asking for RFI from the wireless card to come join the party. There is also a goodly amount of transmitted noise from the display.
RWA had trouble with noise pick-up when they tried mounting Auricaps outside the case.
There might be a possibility of fitting those caps inside the Transporter.
Right now, SB mods are taking around 2 weeks.
