0 Members and 1 Guest are viewing this topic. Read 8138 times.
Guy...I'll see if that can be arranged....I briefly had a Bolder-modified SB3, but sold it to get the Musica so I wouldn't have to use my computer. A friend has a Squeezebox and I'll see if he'd like to bring it over sometime to compare.
LightFire: Your post certainly adds considerable value to this thread. Your input is weighty, to say the least. Also, your avatar seems appropriate.Regards,Larry Welsh
What I stated is the truth. Some people have misconceptions about what digital means. Some people may think that digital audio consists only in another technique to record sound, the same way that carving sulks in a vinyl disc is one and recording electric analog signals in a magnetic tape is another. The difference between digital and analog is a lot bigger than that. When you transmit a digital signal from a DVD player, for example, to a amplifier no sound is transmitted. An encoded information that tells your DAC how to make the sound is transmitted instead. And because the DAC detects any error that occurred during transmission and "asks" to the source to retransmit it until it gets it right. It makes irrelevant anything that comes before the digital audio conversion phase. Unless you have defective parts in your "source system", but in this case problems would be easily detectable.I will post some information about digital audio in a near future to clarify some points.I notice you liked my Avatar!I like The Stooges too.
