0 Members and 1 Guest are viewing this topic. Read 5830 times.
Bob,Thanks for all the info you provided...This is an example of my confusion, these units are within about $100 of each other.Creek Evo - 85 watts with >10 amp outputCreek A50IR - 50 watts with > 18 amp outputSo do you go with the higher watt model or the higher amperage in a case like this?
Welcome TSB,Amp recommendations: check out the AV123 circle for the $1000 Onix SP-3 tube amp, NuForce (see circle below) $1200 IA-7 integrated digital amp would both be excellent choices. Unison Unico P (50 wpc, $1200 new) or the original (80 wpc, ~$900 used) hybrid amps (tube pre-amp section and solid state power amp section, which is a typical audiophile recommended coupling) would be very good too (and can be modded). A Scott Nixon 40 wpc chip amp for ~$900 would be a different but viable option. I'm sure you can get dozens of amp recommendations from around here.
