0 Members and 1 Guest are viewing this topic. Read 7490 times.
The other issue is actual edge diffraction due to the shape and dimensions of the edges of your baffle, because these effects are far greater with OBs since the velocity of movement is greater than with boxes. This last part is where I believe the vast majority of OB designs are flawed, including SL's Orion.
I know bastanis does this on the prometheus OB and stresses its importance but I can't remember why? maybe you can find more info on his websitewww.Bastanis.comJohn
