Burwin 1201 A Dynamic Noise Filter
0 Members and 1 Guest are viewing this topic. Read 874 times.
bvak
« on: 3 Sep 2006, 03:50 pm »
I just recently picked up a Burwin 1201A without a manual.  Can anyone tell me how to hook it up.  On the back it has RCA connectors for Left and Right Tape Record, Tape Play, Input, & Output.
Thx......
TomS
Re: Burwin 1201 A Dynamic Noise Filter
« Reply #1 on: 3 Sep 2006, 04:52 pm »
I used to have one long ago.  Just hook it up in the tape loop in your pre if you have it.
jeffreybehr
« Reply #2 on: 3 Sep 2006, 05:16 pm »
WAY back in my LP days, decades ago, I used one of these.  If used not too aggressively, that is, if set for a smallish amount of noise reduction, it worked quite well.  Worked best on continuous noise such as tape hiss.
