What do you use to clean your speakers?
0 Members and 1 Guest are viewing this topic. Read 2134 times.
zybar
« on: 3 Sep 2006, 12:15 pm »
What are you guys using?
I want to maximize that beautiful finish without possibly damaging it.
George
StevenACNJ
Re: What do you use to clean your speakers?
« Reply #1 on: 3 Sep 2006, 12:51 pm »
I do not own Salk speakers.
However, I was previously looking for a good quality wood cleaner/polish & was recommended this product. It works very well. They also have some nice spray cleaner/polishes:
http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=937-775
Gibson guitar polish also works very well. Can be found at most musical instrument stores,
« Last Edit: 3 Sep 2006, 02:02 pm by StevenACNJ »
gitarretyp
« Reply #2 on: 3 Sep 2006, 02:45 pm »
I'll second the guitar polish, though i prefer the martin polish to the gibson. Use a cotton diaper to apply/wipe-off.
