How do you install/remove chasis screws without removing the paint from them?
0 Members and 1 Guest are viewing this topic. Read 1026 times.
Doublej
I am contstantly nicking the the paint from the inside edges of chasis screws when I install/remove them. Is there a secret to keeping them perfect? Am I just a klutz or is there a special screwdriver tip made out of plastic that should be used or ???
« Last Edit: 1 Sep 2006, 10:48 pm by Doublej »
Wayner
Unless the screws are z-coated they will nick up. A lot of manufacturers simply spray paint the screw heads to match the housing color and the bond is poor. If the housing is black, the best screw will have a black zinc oxide coating on it and will be less prone to "chipping".
W
Russell Dawkins
If they are Phillips head, the most common problem is a slightly undersized screwdriver bit. If you try to use a #1 bit in a #2 head, you will cause damage. Philips are really dependent on a good fit. Snap-On make the best fitting Phillips I've tried - ain't cheap, though.
Levi
It is friction.  Try using light oil and the correct size tool.
