0 Members and 1 Guest are viewing this topic. Read 10555 times.
Shouldn't the speaker's (reactive?) impedance be a factor?
Hello gitarretyp, I am not familiar with this particular model so do not know what the bias settings are for the amp. What you are experiencing is usually an indication of under biasing the tubes. There are obviously other options to consider. If you can answer a few questions, we can probably figure this out. How does the amp perform at "normal" listening levels? What bias voltage, in mV, are you reading at the cathode of the output tubes?
My rationale for the 12au7 comment was that it is known to have pretty high distortion, the 12bh7 which is a drop in replacement has less than half the distortion (at normal operating points). So if the amp is grossly distorting because of the driver stage (my hypothesis) then this should yield an audible difference and help determine if that is the case....
12ax7 wouldn't work in this case. I'd try to hunt down some dirt cheap but working 12bh7's (just a pair).I don't have a pair or I'd loan them to you. You can see if tubesandmore.com has a used pair, which are usually a lot cheaper. If it doesn't help, flip them on ebay for little or no loss.
This is a long shot, but are you sure you're reading your voltmeter correctly? My first tube amp, a PP Assemblage EL34, called for a 40mV bias setting. I set the bias so my digital auto-ranging meter read 40, and the amp clipped at relatively low volume levels. Then I discovered I was setting the bias to 4mV instead of 40. Turning the bias pots up until the meter read 400 solved the problem. I had been misreading the range indication on the meter.
