Variable input to Aksa 55
0 Members and 1 Guest are viewing this topic. Read 2383 times.
oldtimer
  • God gave us ears to Listen
« on: 31 Aug 2006, 10:30 am »
Hi all. I need to install a variable input to my 55n. Is it as easy as it appears. Can I just add a good pot across the input, and if so what would be a good value for the pot.
Thanks in advance.
Nigel
Greg Erskine
Re: Variable input to Aksa 55
« Reply #1 on: 31 Aug 2006, 10:47 am »
Yes it is easy. This article starts at the basics and gets more involved as you read.
http://www.siteswithstyle.com/voltsecond/12_posistion_shunt/12_Position_Pure_Shunt.html
I think 20k or 25k is the recommended value.
andyr
« Reply #2 on: 31 Aug 2006, 11:00 am »
Thanks in advance.
Nigel
Hi Nigel,
I think Greg's given you the correct value but if you've been following the "Volume Setting ..." thread, you'll understand that there are pots ... and there are pots!   :)
The most expensive - but IMO the absolute best, sonically - would be a TKD stepped attenuator with some Vishay shunt resistors.  However, this is serious money (about US$370).
Read the thread and it will become clear.
Andy
oldtimer
« Reply #3 on: 31 Aug 2006, 11:33 am »
Thanks Greg, and Andy. Yes I will want to put a good pot in place. I dont want to hurt sonics.
Thanks again
Nigel
fajimr
« Reply #4 on: 31 Aug 2006, 01:04 pm »
nigel
You might want to try some of Scott Endler's attenuators.  I have a pair in my system (EastSound CD5 --> 55N+--> Ellis 1801b) while my GK-1 sits in the closet waiting to be built  :|  I've been quite happy with them as they allow the music to come out pure and simple.  For 80.00 plus shipping, they are hard to beat.
http://mysite.verizon.net/vze4c5pt/index.html
PSP
Variable input to Aksa 55... done it twice!
« Reply #5 on: 31 Aug 2006, 01:06 pm »
Nigel,
I've done exactly that twice.  I've built two "integrateds" using RCAs for multiple sources, a Grayhill selector switch, followed by a nice pot (the first was a 20K DACT, the second was the cermet pot that Hugh included with the GK-1... also 20K I think).  This works extremely well.
I like the GK-1 and TLP-N better than this passive setup, but that is just a matter of taste.  I think that many would find this passive setup extremely nice.
Peter
oldtimer
« Reply #6 on: 1 Sep 2006, 10:57 am »
nigel
Thanks fajimr. Thanks for the link. I will seriously consider these.
Nigel
oldtimer
Re: Variable input to Aksa 55... done it twice!
« Reply #7 on: 1 Sep 2006, 10:59 am »
Nigel,
Peter
Cheers peter, I am going to use this more for amp level matching in a multi amp system. Thanks again
Nigel
