Odyssey Site Under Construction?
0 Members and 1 Guest are viewing this topic. Read 1620 times.
BobC
« on: 29 Aug 2006, 03:17 pm »
Went to odysseyaudio.com and it said something like..."this is the future site if Odyssey Audio"  or someting like that.
Could the long awaited web site update be at hand?!?!   :bounce:
Perhaps with lots-o-pics, Candela details, more data on options, cable info, etc?  Looking forward to the finished product!
Doug_B
Re: Odyssey Site Under Construction?
« Reply #1 on: 30 Aug 2006, 01:42 am »
It's possible, but it also could be a lost / changed default file spec at the top level of the domain (my guess). All the familiar pages are still there, including the home / top level page, which can be accessed at index.htm or index.html.
Klaus, you should check this out.
Doug
djbnh
« Reply #2 on: 30 Aug 2006, 09:09 pm »
Site seems to be at its normal status at this writing.  :thumb:
