RCA and Balanced IC's to amp?
0 Members and 1 Guest are viewing this topic. Read 1221 times.
jermmd
« on: 23 Aug 2006, 09:45 pm »
This has been discussed before but I can't find the answer. Is there any problem using both RCA and balanced IC's to your 2 channel amp? I'm thinking of using the RCA interconnects from my pre-pro for Home theater and the Balanced outputs from a seperate pre amp for 2 channel audio. Ideally, one preamp will be off when the other is on. What would happen if both preamps were outputting to the amp at the same time? I have a McCormack DNA 500.
jermmd
Re: RCA and Balanced IC's to amp?
« Reply #1 on: 23 Aug 2006, 09:48 pm »
I think this thread belongs in The Starting Block circle. Feel free to move it if that helps.
warnerwh
« Reply #2 on: 25 Aug 2006, 06:14 am »
I don't remember the answer for sure either. However I'd not do that if I were you. It seems like you need to put a switching box in so you can stay safe.
PhilNYC
« Reply #3 on: 25 Aug 2006, 01:07 pm »
I think you might want to check with your amp manufacturer to find out if this is ok.  I know that Blue Circle puts up big warning signs to not connect both RCA and XLR connections into the amp at the same time.   Others might have similar rules...
SMc Audio
« Reply #4 on: 25 Aug 2006, 06:21 pm »
Hi Jermmd -
The answer to your question depends entirely on the design of the specific amplifier. In the case of the DNA-500, the input circuit is designed so that both balanced and unbalanced signals are handled *exactly the same way.*  The XLR and RCA connectors are, in fact, tied together, so you should only use one type at a time. If you were to connect 2 preamps simultaneously via both XLR and RCA cables, you would connect their output stages together, and this is a bad thing.  :nono:  You could damage one or both of the preamps. I believe this is spelled-out in the DNA-500 owner's manual - check it out.
Other amplifier designs may have switched balanced / unbalanced inputs and - depending on the exact nature of that switching - you might be able to hook-up both cables at the same time and switch between them. Always check with the manufacturer before trying this.
Best regards,
Steve McCormack
www.SMcAudio.com
