Listening room measurements / How'd you do it?
0 Members and 1 Guest are viewing this topic. Read 1391 times.
pearsall001
  • AAD 2001 monitor
« on: 23 Aug 2006, 08:52 pm »
I presently have a GIK monster bass trap & two Echo busters corner traps. The difference they made was quite noticable. I want to take it further w/ more absorption panels, bass traps, diffusion panels, etc. but first I'd like to measure my room's acoustics. With room measurements I can then decide on a plan of action. Did any of you guys do this & if you did how did you do it? I'm not very savy with this sort of thing. Hopefully the simpler the better.
Re: Listening room measurements / How'd you do it?
« Reply #1 on: 24 Aug 2006, 11:14 am »
You can get a spl meter, graph paper and test tones and do your self.
http://www.audiocircle.com/index.php?topic=17842.0
Or, get a real time analyzer computer software, mike and computer and tell the computer to do it.
Ethan Winer
  • Audio expert
« Reply #2 on: 24 Aug 2006, 03:33 pm »
> I'd like to measure my room's acoustics. With room measurements I can then decide on a plan of action. <
As Max said you can use test tones and an SPL meter, though that tells you only the raw frequency response. Just as important are the time-based problems - ringing, flutter echo, excess ambience, early reflections, and so forth. I use the ETF and R+D software, and both cost $150 from Acoustisoft:
www.acoustisoft.com
There's also the Room EQ Wizard, which is free, but it's a little less capable because it lacks a display of individual reflections. Get it here:
www.hometheatershack.com/roomeq/
--Ethan
