FM Audio through SB3
0 Members and 1 Guest are viewing this topic. Read 1254 times.
Charles Calkins
« on: 20 Aug 2006, 11:22 pm »
 The only FM station I listen to is KKSF 103.7 S.F. Ca. Playing it through a tuner it sounds good. Sometimes(Like lately) I get a hiss. Poor reception and dropout. Thanks to my very good friend rashiki who got it tuned into my Slimdevices network I can listen to it through my SB3 system. Sounds a hell of a lot better than through a tuner. No hiss!!! No fadeout!!! Guess I'll have to retire my tuner. Big puzzlement to me though. I always thought a tuner was the only way to go! Must be something to do with computer technologie.
                           Cheers
                           Charlie
mr_bill
Re: FM Audio through SB3
« Reply #1 on: 21 Aug 2006, 12:24 am »
What is the stream address, so the rest of us can enjoy that station!
avta
« Reply #2 on: 21 Aug 2006, 02:44 am »
Charlie:
A lot of music sounds better through the SB. If you "rip" a cd to a music file on your computer using certain software and then play it from your computer to the SB either with a wired or wireless connection I think you will find it all sounds better.
Guy
