Record/LP storage
0 Members and 1 Guest are viewing this topic. Read 7990 times.
RonB
Record/LP storage
« on: 18 Aug 2006, 08:37 am »
Any recommendation's?-I've got about 250 LP's-I'd like to have them up off the ground at least 6".
Thank You
woodsyi
Re: Record/LP storage
« Reply #1 on: 18 Aug 2006, 12:45 pm »
If you are looking for inexpensive solution any shelves with 12" depth will do.  Staples has these http://www.staples.com/webapp/wcs/stores/servlet/StaplesProductDisplay?ts=1155904739163&storeId=10001&langId=-1&catalogId=10051&productId=48209&cmArea=FEATURED:SC2:CG31
If you want fancier solution, you can look for barrister shelves of varying quality and price.  I like these because they have the right size shelf depth and have glass doors to keep dust and pets out.  Here is an inexpensive one. http://www.stacksandstacks.com/html/112895_four-door-four-shelf-barrister-bookcase.htm.
DARTH AUDIO
« Reply #2 on: 18 Aug 2006, 01:27 pm »
www.boltz.com    These are the best!! I own three of their 5 shelf LP units (each shelf holds 185 records) and a CD-1200.
Songforyou
« Reply #3 on: 18 Aug 2006, 01:36 pm »
I just bought this from IKEA.  It's available in 2 and 4 shelf versions.  Records fit non-adjustable shelves perfectly.  Hard to beat at the price.
http://www.ikea.com/webapp/wcs/stores/servlet/ProductDisplay?topcategoryId=15561&catalogId=10103&storeId=12&productId=42078&langId=-1&categoryId=15651&chosenPartNumber=70071367
ohenry
« Reply #4 on: 18 Aug 2006, 02:52 pm »
I got a couple of these at Kmart for about $100 each.  I like the narrow design (no potential sagging) and they are pretty robust.
TheChairGuy
« Reply #5 on: 18 Aug 2006, 03:40 pm »
Henry,
Those KMart cubes are really nice...and reasonably priced.  I get a good discount there as a vendor, too   :thumb:
Did you find them in the ready-to-assemble furniture area?
Thx, TCG / John
ohenry
« Reply #6 on: 18 Aug 2006, 04:53 pm »
Yes, they were in a flat box.  Although it looks to be stacked cubes, it's a four-shelf fixed bookcase.  I bought them last year, but noticed they still had some a few weeks ago.
BobM
« Reply #7 on: 18 Aug 2006, 05:13 pm »
You could always pick up some milk crates and some steel shelving, like this:
http://www.audiocircle.com/index.php?action=gallery;area=browse;album=177&pos=1
I only wish I could still get those wooden crates that you see. Ikea used to carry them, but alas, has stopped.
Bob
JoshK
« Reply #8 on: 18 Aug 2006, 05:40 pm »
There is a guy on audiogon advertising such crates at $40/crate made of cherry.  I think that is a bit spendy but if you wanted such you can get them.
RonB
« Reply #9 on: 21 Aug 2006, 11:57 pm »
Thanks to EVERYONE :wink: for their input! :thumb:
Wardsweb
« Reply #10 on: 25 Aug 2006, 04:10 am »
Here is an IKEA shelf from their EXPEDIT line I use:
JoshK
« Reply #11 on: 25 Aug 2006, 01:58 pm »
wardsweb,
tell us about those speakers!
Wardsweb
« Reply #12 on: 25 Aug 2006, 02:06 pm »
wardsweb,
I don't want to highjack this thread so I'll start another.
